Sir, when we do springback comparison result are shown in displacement
is that result shown in displacement consider as springback angle in degree.?
it is in Radians. you need to convert it to degrees.
is this correct if so then my result after springback are wrong because i got value after springback is 0.5 means its 30 degree and this value is so much as springback angle. please help in this regard is displacement value we get from sprigback is in radians?
how are you comparing the springback. by positioning the previous step results component on after springback analysis component?
please someone teach me how to check springback results
