I want to use TPU 95 A (thermoplastic polyurethane) for the analyzes I want to use which material card and its properties should be used for its analysis.
Hi
Please mention the solver you are using for this analysis
I m using same material my friend we performed tensile test this material maybe it behave as hyperelastic material
Hi Please mention the solver you are using for this analysis
I use Optistruct for vibration analysis
Hi guys !
For the TPU 95 A material, you can model it using MATHE card.
Normally, we perform an optimisation simulation in order to identify the right coefficients (we assume Neo-Hook, Odgen, ... behaviour law). And then for FEM simulation, we use what we identified (in the optimisation procedure) to run for example Tensil Simulation ...
Cheers,
Hi guys ! For the TPU 95 A material, you can model it using MATHE card. Normally, we perform an optimisation simulation in order to identify the right coefficients (we assume Neo-Hook, Odgen, ... behaviour law). And then for FEM simulation, we use what we identified (in the optimisation procedure) to run for example Tensil Simulation ... Cheers,
for Poliproplene?
Yes. You can use elasto-visco-plastic (Hollomon and Norton law or ...) behaviour law as well.
I joined an example of the modelling procedure.
