hello
I'm new to HyperMesh my problem: I have a piece of import catia to hupermesh, I can not apply boundary conditions and loads on the nodes
thanks
How are you applying loads and BCs?
Please go through the video https://www.youtube.com/watch?v=mRKofhtoP9Q which gives you an idea on how to apply BCs and loads.
if you are following same as shown in the video, please do the following:
open HyperMesh and load the model. Check if you are able to apply loads and BCs on your model and let us know if you still have the issue.
thank youI delete the files you've told me, I can not apply the constraints ( http://cjoint.com/?DHtmV34LDHU)my file is a CATpart
http://cjoint.com/?DHtm2GHgw97
jeunehomme30,
looks like you are trying to apply loads and BCs on points (not nodes)
you have to mesh the part first. this creates nodes and elements.
I suggest you to go through the link http://training.altairuniversity.com/modeling/meshing-2/ where there is some knowledge base on Geometry cleanup, Meshing, etc..
ok thank you
Thank you, I created the bindings http://cjoint.com/?DHtnCP1axPAbut to load them are not created, the nodes become gray, and the charge does not apply?
hi
i have this probleme http://cjoint.com/?DHtn6DPIUHb
Your tetra elements need a psolid property assigned to them, they currently do not have any property assigned to them, hence the error.
You can watch these set of videos to understand quickly how to do a linear static analysis in HyperWorks
http://training.altairuniversity.com/analysis/structural/linear-static-analysis/analysis/
ok thanks , my calcul is running
