I need help to add motion to a ball joint between two bodies. I am looking for a method on how to control motion with 3 Euler angles. Is there anyway ?
thank you !
Maybe you can use generalized constraint using the 'THETA' Euler function.
As soon as solver hits the gimbal lock, solver will stop.
