Radial and planar symmetry?
Altair Forum User
I am investigating the design of a simple wheel rim,
I see that when radial symmetry is applied, planar symmetry cannot be simultaneously applied. When a different symmetry is applied, the other one is lost. It's either one or the other.
That seems strange as I want the inner and outer sides of the rim to be symmetrical as well as the radial symmetry... because it's not for a car or something complicated, it's just a basic wheel.
Is that right?
Radial symmetry should suffice, you can follow the tutorial here
using extrusion manufacturing constraint can help if you need the shape to have the same cross section through and through...
