HM Automation
User: "Altair Forum User"
Updated by Altair Forum User
I am writing script in hypermesh tcl command to create 3D meshing. for these i not understand  what the numbers mention here (8,0).
it is working in HM_13   and not in 14
*solidmap_prepare_usrdataptr 'SOURCE' 8
*solid_prepare_entitylst elements 0
Let me help to solve the issue.
Thanks,
C.Jude Antro
1 - 4 of 41
    OP
    Hi Jude,
    For  *solidmap_prepare_usrdataptr 'SOURCE' option is a flag that indicate different option for solid mapping. Based on nodes or lines or surface or elements selected for solid mapping this value is calculated.
    For *solid_prepare_entitylst 0 has to be kept and it is reserved for future use.
    OP
    Hi George,
    Thanks for your reply,
    I have one more clarification, i have to select the outer most element in a selected component how can we select it through TCL script.
    I tried to get by element id but the number are not in order if i renumber also not work, how can i choose the outer element.
    Thanks
    C.Jude Antro
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Hi George,
    You can't do that selection by elem ID.
    Here's my method:
    • Select 3D elems => Extract 2D faces (new component ^faces)
    • Select 2D faces => elems => by adjacent => remove ^faces from selection => Got elems (see screenshot)
    Based on my method, you can write a TCL script for that.
    User: "Pandurang"
    Updated by Pandurang
    @jude Antro
    please try this:
    *createmarkpanel comps 1 ' Select the component '
    *findfaces comps 1;
    *createmark elems 1 'by comp name' ^faces;
    eval *createmark elems 2 [hm_getmark elems 1]
    *appendmark elems 1 'by adjacent'
    *markdifference elems 1 elems 2
    set outer_elems [hm_getmark elems 1]
