Dear Powerful Technical Experts,
When I perform EDEM-FLUENT coupling simulation via DDPM interface, I have a little confusion in the official tutorial, since the DDPM model is activated, should I select "Granular" for the second phase in the multiphase model or not? While there is no such step in the official tutorial. And the behavior in simulation are completely different via select it or not.
Also, what is the reason behind this?
(The Eulerian multiphase model in ANSYS FLUENT allows for the modeling of multiple separate, yet interacting phases. The phases can be liquids, gases, or solids in nearly any combination. An Eulerian treatment is used for each phase, in contrast to the Eulerian-Lagrangian treatment that is used for the discrete phase model.
ANSYS FLUENT's Eulerian multiphase model does not distinguish between fluid-fluid and fluid-solid (granular) multiphase flows. A granular flow is simply one that involves at least one phase that has been designated as a granular phase.)
