How can I find out the total body mass in LS-Dyna after I set the density?
Hi
Try using panel tools>mass calc
Also you can use Model browser --> component view to check the individual mass for all components.
Hi Try using panel tools>mass calc
I tried the Measure-> Mass, but I just get the value 0
Please confirm whether you assigned material to component
Click on component browser to view as Udhay guiding
Maybe you forgot to input density in material?
Also when you checking with tool --> mass calc.. check whether area is shown or not. If it is shows, then check the volume.
If thickness is mistake it will give zero volume & zero mass.
If Material is mistake it will give volume data & zero mass.
