HI All, what is the best way to know if the component is empty. I do not want to delete if there is anything. Some time the nodes, elements are mask and there is a change that you might accidently delete them.
Thanks
Ray
Hi Ray
in panel F2-delete you click on 'preview empty' then click 'delete'
You can also try by right click on the component and click on isolate.
Thankyou
F2-delete and preview empty sounds like a good option but it says 4 entities are empty. But i have over 200 components but which 4 entities? its really hard.
thanks
Hello Ray
You could use the model browser to achieve this.
Just go to model browser
Once you are in the browser right click on the 'Component'folder-> in the context menu select 'empty'.
You will get a dialog which shows you all the empty components in your model. Just select them and hit delete.
