Hello everyone,
I have a few questions regarding HyperXtrude 17 that I would like to ask.
Is it possible to perform a parameter study (DOE) with HyperXtrude? I would like to automatically perform simulations with varied process parameters (for example: ram speed, workpiece temperature, tool temperature) without having to set up each time the simulation manually.
Regarding the JobManager: what is the difference between the 4 solver hosts that I can choose from?
hxME_3055
hxME_3055_os (I assume this one is for OptiStruct) hxME_3581 hxME_3581_os I am also trying to use heating elements in the container. I would like the heating/ cooling to start after a certain time. However, I am not so sure how to define the function in the GRF-File.
Thank you in advance.
Best regards,
Chiara
