What is element baising?? How to use it??
The automeshing process allows you to bias the placement of nodes so that their intervals are not uniform in size. You can designate that the smaller intervals go near the start of the edge, near the end of the edge, near both ends with larger intervals in the middle, or near the middle of the edge.
you can use this in the interactive panel of automesh,
See -
HyperWorks Desktop Applications > HyperMesh > User's Guide > Meshing > Surface Meshing > Automatic Mesh Generation:
