I am doing composite wing analysis and I want to create data sheet which contains name of the plies and their P1 major stress value using matrix browser.
I opened two windows, one with .fem model and the other HV window with results.
I am able to create list of name of plies but when I choose this plies as entities and try to get HVdata, result but I don't see P1 major in results.
If I select elements as entities this works fine but with plies it doesn't work.
Is there a work around to get my task done?
Picture displaying the issue is attached.
Thank you in advance.
