Hypermesh with parallels on MacOS
I'm trying tu run hypermesh 13 on a Mac Book Pro Retina (El Captain) with Parallels 11. Hypermesh starts fine but the display screen (where the model is displayed) remains black whatever I do (load model, modify the view...).
If I deactivate the direct X 10 graphic acceleration in Parallels, the display is fine and I'm able to see the model and work on it but of course everything is very slow so it is not an acceptable solution.
Is there a known workaround to make Hypermesh work with Parallels and graphic acceleration ?
I'm aware that a MacOS version of the Hyperworks suite exists but it is not compatible with El Captain.
Thank you.
Hi YakDetrak,
Could you please let me know about the graphics card installed on your machine?
- Open System Profiler by choosing About this Mac from the Apple menu, then click More Info.
- Select the 'Graphics/Displays' item in the Hardware section.
0 -
Thank you for your answer. Below informations on my graphics card :
Intel HD Graphics 4000 :
Jeu de composants : Intel HD Graphics 4000
Type : Processeur graphique (GPU)
Bus : Intégré
VRAM (dynamique, max.) : 1536 Mo
Fournisseur : Intel (0x8086)
Identifiant du périphérique : 0x0166
Identifiant de révision : 0x0009
Moniteurs :
LCD couleur :
Type de moniteur : Retina LCD
Résolution : Retina 2 560 × 1 600
Retina : Oui
Profondeur de pixels : Couleurs 32 bits (ARGB8888)
Moniteur principal : Oui
Miroir : Désactivé
Connecté : Oui
Intégré : Oui
0 -
Could you try setting the environment variable as
Variable name: HM_DISABLE_MULTISAMPLE
Variable value: 1
