I want to know what is the difference between 'node coordinates' and 'node coordinates (tracked)'.
Node coordinates: This specifies x y and z coordinate from global coordinate system.
Node Coordinate : This specifies x y and z coordinate from local coordinate system which you have created in your model using tracking system.
