Can you kindly help me with evaluating the result file. How do I get the .res files? Or how can I evaluate the results without that file.
Also, it would be of great help if you could help me with the procedure for adding or editing the FLC curve (forming limit curve) for the material. The tutorial says it has an option for FLC under the setup tool. But I could not find that option in the setup menu. I am using the Hyperform 2017 version.
Kindly help me as soon as possible.
Thank you again.
