hello!
Is there any way to save the result of Lattice optimization in step format?
thank you.
Hi Ffog,
With Inspire 2017.3 the Lattice optimization will allow you to compare different performances for a Topology Optimization and Lattice Designs. At this moment, export is not supportet.
If you are an advanced user, you might use Altair Optistruct and Altair Hypermesh to do further investitations for Lattices.
Kind Regards,
Felix
If I can not export, why is this helpful?
Yosef,
If you have acess to 3matic from Materialise, you can import the FEM deck from the Inspire scratch folder to create a AM deck (which is a materialize format) or a huge STL.
Thank you
Yosef, If you have acess to 3matic from Materialise, you can import the FEM deck from the Inspire scratch folder to create a AM deck (which is a materialize format) or a huge STL. Regards, Felix
Hi Felix,
can you specify how to do this?
Thanks!
