Black volume
Can you please share the model so i can see how it is on my PC.
Thankyou
0 -
This is the Catia model. Is very simple. I've try with another models and it's the same with all of them, so I don´t know if the problem comes from the model or from Hypermesh.
Thank you very much!
0 -
I had something like this happen a few years back, and the 'fix' (discovered quite by accident) ended up being to change the color of the system collector. Seems like a long shot here but may be worth a try.
0 -
Okey, how can I change the color of the system collector?
Thank's!!
0 -
For the time being please find attached the .hm file of your Catia Part.
I have asked some developers about this and will get back to you as soon as possible.
Thankyou
0 -
Hello there,
I have recently installed Hypermesh and I am facing the same problem i.e. the volume appears black but the other things works just fine. Please help me to rid of this problem.
Thank you.
0 -
Altair Forum User said:I have recently installed Hypermesh and I am facing the same problem i.e. the volume appears black but the other things works just fine. Please help me to rid of this problem.
The reason is the mesh lines. When you zoom out, they are kind of converged and makes the component look like a black colored component.
Zoom into the model and it should show you the component color (if it is not black),
0 -
Hi Prakash Pagadala,
No i tried either ways i.e. zooming in /out, the component still appears black. I don't understand why this happens ?. Anyways, if you find any solution regarding this problem please do share with me.
Thank you.
0 -
Can you share the .hm file, please?
Please use the file transfer link in my signature to share the model file
0 -
Hi
I have send you a practice file. But, whichever model i try open appears as a black volume.
Thank you
0 -
Since this is happening with all models, the issue could be with the graphics card.
Here is a similar issue,
https://community.altair.com/community?id=community_question&sys_id=ada60c7a1b2bd0908017dc61ec4bcbbb
Attached is a list of supported graphics card for HyperWorks 2017
