ruled panel
there are multiple ways through which you can achieve good mesh using ruled command.I believe you would have selected end mutiple edges along the length of box.edge to edge would also work fine.
0 -
hi, Rahul
Thanks for your answering. I did this as the picture below shows. I don't know why. Could you tell me where am I wrong?
0 -
Could you share hm file for same?
0 -
It's because fix points on 2 lines are not parallel to box axis
In your case, use 2d>drag is better
0 -
0 -
thanks for your answering
I also found this, but the fix points could not be suppressed or released. What should I do, if I want to make them parallel?
0 -
thank you very much
But I tried to remove fixed point, the suppress and release commands are not work. How could I change the fixed point position? thanks!
0 -
You cannot remove fixed point if it is unique on the line, add new fixed point then remove the old one (F11> add/remove point)
0 -
Thank you very much!
