Hi everyone,
Can anyone please tell me why .sta file not created after the end of forming simulation?
Thank you very much.
Please check if you have set /STATE/DT in the engine file.
Hi Prakash Pagadala,
I checked and it set. But it still did't generate. Why?
Usually if the forming animation count set to 10, A001 until A011 will generate at the end of simulation right?
And then the .sta file will now generated, correct?
My case is the solver showed job completed after A010 generated.
Both blank and tools with automesh.
Thank you.
I manage to get the .sta file in forming simulation.
But when I use the .sta file for trim or flange process, it show the warning that state file has no result.
Why?
