I need your advice again.
I have two beams with a C crosssection. They are modeled by 2D-elements.
The beams are co-linear and I want to connect the Ends of both beams (Frames) to get one beam as there is a gap between them at the Moment.
A possibility would be the usage of RBE2, but I think closing the Gap between them with Shell elements is the best solution.
The mesh size differs a little bit.
Do you have some ideas how i can connect/Close the gap?
Thanks a lot
