I am trying to mesh a very complex set of 2D planes which intersect at varying orientations. THe first image shows an example of the type of geometry I am working with.
I am able to mesh the geometry, however, the numerical simulation is not very stable due to some of the extreme distortion of elements at some of the intersections.
I would like to know if there is a way in HM to refine these problem areas automatically. Is there a threshold value that I can adjust. I am new to this software and also to finite element meshing in general.
I also attached a picture of some of the problem areas I am referring to.. you can see in the black circles that some of the elements are collapsed and therefore very small relative to the nearest neighbour.. I think this is the problem. How can I control this to get some sort of refining in these areas.
