Hello everone,
is there an implemented function in HyperStudy to export the final configuration of design variables in an .hm or .fem file for further analysis and modeling?
Thanks in advance!
There is an environment variable to specify the HyperStudy input argument.For example:set ::env(HW_HST_CMD_ARGS) ”-studyfile /projects/p1/test.xml –preffile /projects/p1/utils.mvw”Hope it helps.
Regards
Rahul R
