I'm having a little confusion with defining a motion using markers. As seen in attached image, even though all translation and rotations which are available can be defined with respect to marker 2, there is still a selection for marker 1, which seemed irrelevant to me. I have checked the doc page, and what it says about the marker 1 and marker 2 fields is: 'Select the first and second markers to which to the motion is applied.'
I find this confusing, as there are translation/motion options only for marker 2. And by intuition, I should need only one marker to define a motion with respect to it. Why do I need to select a marker 1? I would appreciate any information to clarify this.
Thank you.
Sincerely
