hey, i am new to hypermesh and i want to create mesh then export it to fluent, while the mesh is being exported successfully i face problems when i run the fluid simulation. i see the analsysis for only 1 mesh thickness and the flow is not going any further . i created a simple geometry to test my hypothesis. i suspect there is a problem is treating the body as fluid, kindly guide me.
