I've been recently working on a Knee joint model . I need to find the contact force vector between two particular components. I have been getting a lot of errors and unable to run the model.
All the contact pairs and properly defined and I am able to generate all typical outputs except for contact output. please help me out. The output blocks defined so far are node and element outputs for all 8 components defined.
Thanks in advance!
<?xml version="1.0" encoding="UTF-8"?>.thumb.png.20568e88260a1b25f47fa789143383fd.png)
