Hi AsahelM
Torsional results are available in results. the following are the supported stress results for 1D elements
Hi AsahelM Torsional results are available in results. the following are the supported stress results for 1D elements
Hi Prakash Pagadala, thanks for your reply
But in the results type in hyperview there is an option to show the CBAR/CBEAM Torsional stress,
I think that this kind of elements allow torsion, actually I can see the rotation results of the 1d element but I can see the stress results.
I don't know if there is an option where I can select a point to measure the torsional stress (like I did for bending with the recovery points)
