I want to perform variation of steering axis inclinaison for a front suspension how can i do this in motionview ?
@riham1994
After loading the assembly you can change the hard points for steering column to change the angle of the steering axis and run the analysis.
i didn't mean by my question this, but i want to see the variation of the steering axis inclinaison as a fonction of ride and roll it should give something like this
If you are using assembly wizard, you can view steering angle variantion in analysis report at the end of the analysis
from where can i open this log file ?
