I need some example or tutorial for structure analysis focus on welding on T - joint ( I need to simulation for welding separation on main part)
PFA screenshot from practical finite element analysis book.You can also refer Hypermesh connectors tutorials.
PFA screenshot from practical finite element analysis book.You can also refer Hypermesh connectors tutorials. <?xml version="1.0" encoding="UTF-8"?>
Can i applied with Hollow square box stell
please share screenshot of your model.
If you are not interested in weld failure then you can model weld region using rigid element.You can refer below tutorial as reference.
OS-4000: 3D Size Optimization of a Rail Joint
