HI All,
can you please tell me if i can move the component up and down in model view in hypermesh for better organization.
On my attached file i want o move Aft_Spigot_pin_5 down and Aft_Spigot_pin_4 up.
Hi Ray
just click on column header 'Name'
Hi Tinh,
can't follow. can you please explain more with picture?
Click on the top most area of the column within model view.(The header)
This should sort the names (ascending/descending)
Thanks Kevin,
suppose i have two assembly explain below
Assembly_1
-component_1
- Component_2
Assemblt _2
-component_3
- Component_4
is it possible to slide component_3 into Assembly_1?
Thanks
Yes, all you have to do drag and drop that component into the assembly of your choice,within the browser
