I am using batch mesh to mesh engine head. On each attempt it is reaching 63rd step and then stopping due to segmentation error. It resumes but, do not complete the mesh. With smaller components this method is working fine
Hi Alekh,
Can you delete setting files and try again?
try duplicate surfs of comp to a new comp, delete old surfs
sometimes I see this has effect
Hi Sir,
how to clear the older datas in hypermesh like as material, properties and other details in previous session...
Just right click on materials, properties,... on Model Browser and select 'Delete'
cool,
I will start a new model but the older model details shown defaultly... so how to format the older details...
Do you mean you need to edit the old Material properties?
If this is the case then right click on the Material and select Card edit.
Thankyou
Hi sanjay,
when I create a new model and create a material like steel but previous model material as shown on window. so how to clear the older model details in the current or new model...
I hope u understand my word...
Thanks to reply.
Can you please share the model so i can better understand your problem.
pls see this image...
Please use the create/edit option to edit the values.
pls see this image... <?xml version="1.0" encoding="UTF-8"?>
Oh my god. Just click on position of 'steel'
If i were you i would click on everything to see affection. Hypermesh is not a bomb, why are you afraid of it?
