Hello everybody
I have been using ProMan for a while now but for certain simulations I get some serious deviations from the theoretical values that I calculated.
To identify the reason for this difference I wanted to see the phase of every wave that contributes to the field strength of a point.
However the log files that are generated only contain information about the path, transmission matrix, delay, field strength components and so on.
I can calculate the phase difference between several paths (for example one direct path and a reflection) based on the delay and path length difference between them but i can't seem to find exact phase information for each path.
Is there a way to gather the phase from a path, wether indirect or direct, or does ProMan not have such a mechanism?
For the simulation I checked that the superposition of contributions is coherent and considers the phase.
These mismatches are mainly present when there are reflections.
Thanks in advance.
Publi
