Non-linear modal analysis
User: "Altair Forum User"
Updated by Altair Forum User
Hi everyone,
I am currently trying to perform a modal analysis of a component AFTER it has been loaded with a force. During the loading step, some parts of the component engage in SLIDE type contact.
I use OPTISTRUCT.
I currently plan to make two loadsteps for the analysis:
1.A non-linear quasistatic step during which I load my model and contacts are engaged
2.A normal modes analysis which should compute the modes for the deformed structure obtained after step1
Is this possible in Optistruct?
Thanks in advance for any answer.
Regards
Matteo
1 - 6 of 61
    OP
    Hi @Matteo
    Please use STASUB (PRELOAD) in Normal modes subcase which should reference the NLSTAT subcase.
    I think this should help.
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Hi @Matteo
    Hi  @Prakash Pagadala
    I am trying this but it comes with error 'Case Control data LOAD=3 is not referenced by any bulk data relevant for used subcase type.' I have attached files for your reference. Kindly help with this.
    Sorry!! Couldnt see the obvious mistake there. Issue is resolved. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "Karthic_22061"
    Updated by Karthic_22061
    Hi Nachiket,
    Try removing the dummy load referred by the static load case. else provide the load for the load collector 3.
    Hi Nachiket,
    Hi Kathic
    I already resolved it. Thanks anyways!!
    OP
    Sorry!! Couldnt see the obvious mistake there. Issue is resolved. :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
    ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20'>
