Laptop Hang
When I do automesh in Size and bias mode select the element size as mixed and size as 2.5e-01 and mesh it, Hypermesh becomes extremely slow, It does not respond sometimes and even when it does, it lags extremely(to rotate the geometry and all the other stuff). It doesn't even show the mesh after pressing the mesh button as shown below just a few nodes. It functions perfectly well for all the other things.
Specs- i5 (2.1 GHZ)
8GB ram
2GB AMD Radeon M330 graphic card.
What can I do?
I've installed the software by downloading it properly from the site. I use Windows 10
From error it is clear that the Element size is closer to node tolerance. Press O on the keyboard to enter options panel.See attached screenshot.
Check the dimensions in Hypermesh using distance panel.If it any changes happens then use appropriate scale factor while importing geometry.
Regards
Rahul R
0 -
okay, I got that but after I mesh a surf, my mesh is not visible properly, it looks black completely. What should I do to view it?
0 -
Could you share us your hm file?I think using zoomin you can view those element.By the how many element it has created?
Regards
Rahul R
0 -
Sure.
Is forums the only way I can ask? I have a strict deadline and I need to do quite a bit before Feb end. 1 day/problem would not be fast enough. Aren't there any phone helplines or chats where people would reply and resolve the problems soon enough? Element size 1.5
0 -
Sorry to bother you. I zoomed in. Mesh is visible now
0 -
Thanks for the update.We provide support through open support forum.Let us know if you need any help.
Regards
Rahul R
