Sir,
In the pre-processing, as I create the frictional contact in between the binder and blank also apply load on the blank through binder, I expected that the simulation process will show me the blank being sandwiched in between the binder and die with zero clearance in between them.
But as you can see, attched snap of the simulation in the result visualisation through HyperView, there is gap between the blank and binder as wellas blank and die surface,
Is this because, the 3D mesh visualisation is OFF ?
If so, how do I enable it in HyperView?
