RBE3 Line
Hello
I m a new beginner in CAE and i need help in hypermesh.
I have create a RBE3 on geometry and assigned with a Force. In my viewer i can see the lines from RBE-Node to the nodes, but when i make an analysis over optiStruct, i can see the results in hyperview with lines too.
How can i desible the line in the results-view, its look not nice?
I hope you can understand what i mean, sorry for my english. i attache some images that can explain better as me words.
kind regards
knot1234
in the visualization tool bar change the Traditional 2D Element Representation to Traditional 3D Element Representation... i think that works.. i'm not sure..
0 -
Hello
i tried, but it doesnt work. The Lines are vesible in the Result view.
I think it must to adjust in any kind of settings.
I use the Hypermesh 11.0
kind regards
0 -
hi,
you can mask it off
0 -
Put your RBE3 elements into a component. So in results view you can turn it on/off easily.
0 -
Helo Q.NGUYEN-DAI,
thank you, this was the way what i did.
i put the RBE 2 elements in component, and could to hide it in the hieperview.
thanks for help
