Hi all,
Is there anyone who has criteria and parameter file of 5mm mesh size to use in Batchmesher except default?
Thanks in advance.
Hi Semih,
The criteria and parameters will vary from user/client to user/client. Based on the analysis and requirements these values and parameters may be different.
And so there is no generalized criteria. The generally acceptable range of values are provided in the default criteria files.
