I want to mesh and get error
Sphere1.Region58 breaks the symmetry definition. Either it does not have a symmetrical counterpart, or it is not symmetrical around the plane.
How can i remove those planes?
Hi bobo44,
From the image, it would appear that the model isn't symmetrical. There are three types of symmetry (geometric; electric; and magnetic symmetry). For each one, you need to understand how the fields and currents will behave in order to know which one is correct.
For this example, I would suggest switching off symmetry planes altogether. You can do this in CADFEKO on the 'Solve / Run' tab -> 'Solution settings' group -> Symmetry. You can learn more about how to utilise symmetry from the User Manual:
I hope this resolves the problem for you.
Kind regards,
Andries
thank you andries, it helped a lot, the model wasnt supposed to be symmetrical, i just edited existing feko eample with my model, that as it.
