Composite modeling Size optimization
Hi everyone,
I m making a composite size optimization and need to use the same design variable to multiple plies.
Simplified, I need several different plies to have the same thickness and I need several plies with diferent thickness aswell.
I formulated the problem this way and create a generic relationship to each ply, using only one design variable for multiple plies. This didn't work and appeared an error.
I checked the dlink card but I dont know if that fits my purpose because how can I link DVs in order to have the same value?
Any ideia on how can I do this?
Best regards,
Gonçalo
Hi @GonPer
So you have created a DV for a ply and linked this DV to other plies DV, is my understanding correct?
Can you share the error message or .out file?
0 -
Hi Prakash,
Thank you for your fast answer.
The error is:
*** ERROR # 532 ***
Independent DESVAR -2 on DLINK 6 is also declared
dependent on DLINK -2.I created 20 DV. I have 116 plies and made the generic relationship to each ply, linking it to a DV. Each DV has multiple plies linked to it via the generic relationship.
Didn't link DV to DV, linked multiple DVPREL to a DV.
best regards,
Gonçalo
0 -
Also I dont have any DLINK card defined. I guess the error says DLINK maybe because the DVPREL uses a DLINK to connect to DV?
Gonçalo
0 -
Hi @GonPer
Yes,
The error message says the same DESVAR is used on two DLINKS as independent and dependent DESVAR but I am confused with the DLINK ID -2.
I will check with experts and will let you know the solution soon.
0 -
Do you have Ply balance constraint on your laminate?
If yes can you remove the same and try again?
0 -
Hi Prakash,
Yes I had it on. But it isn't necessary because all the 45, -45 plies are connected in the same desvar.
Another thing that did not make sense, was that the numbers on desvars and dlinks in the error were not the same as I defined.
So far is runing without problems.
Thank you very much, I tought that one week of work went down the toilet, but fortunetly no.
Best regards,
Gonçalo
0 -
Good to know that you are able to see some progress.. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
Altair Forum User said:Another thing that did not make sense, was that the numbers on desvars and dlinks in the error were not the same as I defined.
Yes, this looks like a defect which I am going to let Devs know about it so that they can sort this out ASAP!!!
0 -
Hi Prakash,
Thank you for your help.
Just another thing, I dont know why but the SZTOSH option, produced a .fem file that is all changed up.
Different orientations in plies, lost ply systems, different element sets in the plies. So it isn't usable.
When I used this option with simple models it worked ok, I dont know why it didn't work this way.
I will do it by hand, but just for information I think you should let the Devs know aswell so they can improve it.
Best regards,
Gonçalo
0 -
Hi @GonPer
Thank you for letting us know. There was a bug in S/w using othrotropic material and our Devs are already working on it.
I will keep you posted on the same if there is any update from Dev team.
