Hi Guys,
i want to define a pin joint for 2 Bars in x-y-z coordinaten:
for example:
Bar A: pin a : 0 pin b; 456
Bar B: pin a : 456 pin b; 0
but it do not work at all for test problem
Thanks very much!!!
Leslie
Leslie,
I think Bar B Pin B is completely free right?
To release Dof pin, enter the value of Dof in Pin a and Pin b fields.
Prakash Pagadala
you means:
Bar B: pin a : 0 pin b; 0
what can i write in pin a/b, 123456?
for Bar B: pin a is 456 which means allowing rotational DoF in all three directions.
same way for Bar B: Pin b (if you want to allow translation and rotation) input 123456
