Dear All
I recently encountered the error from the picture, 'Error 953: Not enough interactions (total number) specified'.
I have had this error before without any actual problems in my simulation. However this time it seems that my simulation stopped calculating way before my prediciton area was filled.
I have a long and small prediciton area (1 m wide and 50 km long) but it stops showing values for received power or field strength after 1020 m. Is this just the limit for how many points ProMan can simulate? I have the resolution at 10m so it has the same amount of data points as my previous predictions which are shorter but at a higher resolution (for example 0.2m resolution).
Is this related to the error or do I have 2 seperate breaches of conditions?
Thanks in advance!
Publi
