Confusion with unit selection
Altair Forum User
Hi Group
Refering to following Pdf i have confusion regarding unit consistency
I am taking E modulus in MPa
density in Ton/mm3
then will my output velocity will be mm/s
what system should i choose (for E and density) to have velocity in m/s
what does the unit in Pdf density = kg/L . L refer to
Regards
If you want to get m/s for velocity, so use SI system. In this case, E = Pa ; Density = kg/m^3
Have a look at : http://www.idac.co.uk/services/downloads/consistent.pdf
0 -
See http://training.altairuniversity.com/wp-content/uploads/2012/04/Student_Guide_55-57.pdf
chapter on units in the HyperWorks FEA guide,
