I'm using hypermesh v13 with optistruct and I'm trying to do an analysis that involves both gravity and applied loads. I currently have three load collectors. One for constraints, one for forces, one for gravity. I have created a linear static loadstep for the analysis.
In said loadstep, I have assigned the constraints collector to the SPC field. I can then assign either the forces or gravity load collector to the LOAD field within the loadstep, but not both. The analysis takes into account whichever load collector is assigned. So my question is, how do I perform an analysis the includes both applied forces and gravity? I'm assuming I'm missing something simple, but it appears that I can't currently apply both.
Thanks!
