Tried installing WinProp using the setup (WinProp Setup.exe).
The error message attached does not give details on which dll it is associated with.
64 bit,
Windows 10.
Kindly advise.
The WinProp 14.1 installer available on Connect at the moment will run after having installed the vcredist_x86.exe (MS Visual C++ Redistributables Update 3) available under:
https://www.microsoft.com/en-us/download/details.aspx?id=53587
Thanks, will install the MS Visual C++ update and get back to you
i have been able to complete the installation.
However, i also had to download the complete version of DirectX, as the version included in the winprop exe file appears to be missing some files.
Thanks
