HyperMesh Warning
Hello Sir,
Greetings!!!
I have been getting a warning message,' Warning: nodes id 14447572 was found more than once in the import file; Resolution: Original id's maintained. Renumbering the database recommended', when I imported the key file, which I had created earlier (LS-Dyna Input File Format). I have a total of 12,000 warnings regarding renumbering.
I have tried to renumber the nodes in the file, but the warning still exists. It's not causing any harm to my file, but I would like to know the reason why renumbering of nodes is not working.
Hope, to hear from you soon.
Thanks & Warm Regards,
Akshay S Patil
Hi
In panel tool>renumber , switch to sub panel 'all'
I think you did not select the nodes.
0 -
Thank you Tinh. I selected all, as you mentioned in sub panel and renumbered. It did remove the warnings.
But earlier, tool>renumber>single > nodes , I had selected nodes by all. It had renumbered all the nodes, but I was still getting the warnings. Is there any possible explanation for that, as tool>renumber>Single>Nodes(SELECTION BY ALL) and tool>renumber>ALL , should have same result?
Thank you for Tinh for your answer. Appreciate it.
0 -
Hi
Maybe, you have to select all nodes by shift+LMB instead of menu nodes>all
Could you enter panel analysis>preserved nodes and confirm if some red nodes existing?
0 -
Hello Tinh,
You were correct, I had some preserved nodes in my model. I converted them into temp nodes and cleared them. And it worked.
I think I might have used tool>renumber>Single>Nodes(SELECTION BY Display) instead of tool>renumber>Single>Nodes(SELECTION BY ALL). I apologize for speaking wrongly.
Thank you again.
