Hi
Where did you see them?
if you did not find them in reference guide, then perhaps the commands are for app gui, not for user
for example some menus, toolbars will invoke the commands in certain context
In several case you can dump to see inside these (if they are not compiled)
But should not use directly (same as api functions), almost tasks can be done with hw classes
Hi Where did you see them? if you did not find them in reference guide, then perhaps the commands are for app gui, not for user for example some menus, toolbars will invoke the commands in certain context In several case you can dump to see inside these (if they are not compiled) But should not use directly (same as api functions), almost tasks can be done with hw classes
