Is there a way I can get the Tsai-wu failure criteria index for a Divinycell (Poliurethane foam) material analisys ? I am using MAT8 and P-shell property card. Thank you!
You ask for post-processing?
Yes
You can use Expression builder with Composite result math template to formulate TsaiWu Failure theory
