Hello everyone,
   	I want to create a script, which takes data from binary files (e.g. binout from LS-Dyna, it stores curve data), computes it (e.g. find the maximum value of a curve) and create a result file, which can be used in HyperView (e.g. as a result for a contour plot). To be more specific, I want to create a contour plot for spot weld elements, which contains maximum values (constant over time) of spot weld forces, which are given in a binary output file from LS-Dyna.
   	I did not find an easy solution for this task, therefor I tried to break it down. This describes my plan backwards from the finish to the start:
   	- To create a contour plot from custom data, I can use an XML file, which defines my datatype (see 'HyperWorks Result Math/Creating New Datatypes')
   	- To access data, which will be used for the new datatype, I can create a TCL Plugin or use TCL commands respectively
   	- The data is contained in a binary file. I want to either use HW TCL commands to access the LS-Dyna binary output directly or use the commands to access an Altair Binary Format file (ABF), which might be easier
   	- If I want to use the ABF file, I have to translate the LS-Dyna binary output file via HGTRANS first
   	Further applications could be the storage of the computed values as *.csf file, therefor I am really interested in the reading of this data.
   	Since I am really new to this topic, I would need some opinions and tips for this.
   	Makes the whole process sense or is there an easier way?
   	Which TCL or HW TCL commands can I use to access data in a binary file (LS-Dyna Binout or ABF)?
   	Thank you.
   	Update 1:
   	I wrote a script to access curves, which are plotted in HyperGraph, and store them in a database array. Then I write the data into a CSV file, to evaluate it with Excel.
   	I think this was the easy part.
   	The next question is, how do I read curve data from binary files? Can anyone help?
