I am new to tcl programming and hypermesh.Where can i find the help for tcl in hypermesh. How to use the command window and hypermath to write the scripts.
There're a lot of tutorial, example, guide on the net for TCL.
Google is your friend /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Thanks for your reply. How to find fillets in the sheet metal parts in hypermesh.
Hi Arun,
In Geometry>>Defeature, you will get the option to find fillets.
