I try to model a beam with one end fix and the other a vertical load.The cross section is rectagular. I create the material, the section ( 1D, Hyper Beam, Standard section library:Hyper Beam , Standard section type:solid rectangle), the property(PBEAM; assigning material and beam section). Then I create the extreme node and the element(1D, bars,Cbeam , orientation :Yaxis). I don't understed very well as define the orientation of the cross section.Next i create load collector, create Spc and force, assign load step and chosen the control cards.But I don't know how to select the stress recovery point ( what is M1a M2a... in property card edit?); how to see the element force in Hyperview results (shear plane and bending plane).
Thanks
valentina.
