Altair RISE
Nominate Yourself Now!
Responses not editable
User: "Altair Forum User"
Updated by Altair Forum User
Hi experts,
I am having a problem with hyperstudy where the responses were wrong and not editable. I tried to do like tutorial (HS-2200). The errors are:
414 Error : Design matrix should have at least one active row ( 0 )
               Unable to generate design for ( Fit 1 (fit_1) )
  415 Error  : Error generating design - ( Fit 1 (fit_1) ) - ( Moving Least Squares )
I attached my work file. When I tried to edit the run matrix, it was not working. Please give me some idea. Thanks.
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    I see in the Run matrix you dont have any output responses defined.Please define output response to carryout FIT.
    OP
    Dear Rahul,
    Thanks for the prompt feedback but the problem is every time after put in the response, hyperstudy automatically wipe it off. What I do is under DOE 'approach', then 'Specification', then 'Modify Run Matrix' and put in the response value. After I click apply and then ok, the responses become 'empty' when I checked it.
    I have replicated HS 2200 in latest version HW 2017.2.Please find below ftin link to download mp4 file of tutorial.
    https://ftin.india.altair.com:8443/message/SEaMOMscYhlNk8d1Bpma9L
    I see the csv file which you have copied does not contain Design variable and output response in column like tutorial.Let me know if attached video helps.
